I am new with ATVs, help please?
Old Jun 5, 2003 | 02:02 AM
witti's Avatar
Default I am new with ATVs, help please?
If it wont start by jumping it from a car the bat is not the problem.
Check the ground, also check if you are getting power to the starter.
Old Jun 5, 2003 | 02:09 AM
BlueLeader's Avatar
there is a ground connection to the side case above the left shift lever. clean it with some sand paper and re-connect it.
Old Jun 5, 2003 | 02:42 AM
PADZZ's Avatar
Try push starting it.....
Old Jun 5, 2003 | 11:18 AM
MrMan15's Avatar
As i said, Im new to ATVs...where did u say that ground thing was again?
Old Jun 5, 2003 | 11:35 AM
  #15
MrMan15's Avatar
Ok, I found out that if I keep trying to start it up, really fast, after a few times it turn on! I either have a magic touch, or I think that it is indeed the batter.
Old Jun 5, 2003 | 12:58 PM
  #16
shmoo's Avatar
I had this problem 2 weeks ago. The starter relay is what is clicking. Like Hossblur said there is enough juice to supply the lights but not enough to crank the engine over. I wouldn't recommend jumping from a car but definately put your battery on a trickle charge and make sure all connections are tight. I guarantee that'll work. If your battery doesn't take or hold a charge you need a new battery. hope this helps. [img]i/expressions/face-icon-small-wink.gif[/img]
  #17
BLASTERDEVIL2's Avatar
sounds like its the starter or a bad ground. try cleanig all the connects like blue said.
Old Jun 5, 2003 | 02:27 PM
  #18
MrMan15's Avatar
Thanks guys, ow you all one
Old Jun 5, 2003 | 04:13 PM
  #19
MrMan15's Avatar
Ok....one more question....I found out it was a battery, got a new one....put the acida and what not, and now when I install it, I get one wire thing connected, but when I try to do the other one, it sparks and the quad jumps. How do I install it?
Old Jun 5, 2003 | 04:46 PM
  #20
swftballz400ex's Avatar
first put it in neutral and then if it just sparks but stoips once you keep on the battery go AHEAD AND TIGHTEN IT up. Make sure its charged and try starting it
