Help regarding 2001 KVF 400
Old Jun 5, 2003 | 09:50 AM
Raybourque's Avatar
Default Help regarding 2001 KVF 400
A friend of mine has a 2001 Kawasaki KVF 400 (Canadian Model) and it has a hard to find oil leak. On ocasion there has been oil in the airbox. He has had the bike on a lift and it appears to be dry. Is the carb. blowing back oil into the filter? If so, what is causing this. Any information would be greatly appreciated. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 5, 2003 | 10:46 AM
newbeatle's Avatar
I don't know about the 400's, but the 650's are VERY sensitive to overfilling, if it's just a little too full of oil, it blows it into the filter box... check the oil level... Have A GREAT Day, Go Four Wheel'in !!!!! WAM
Old Jun 5, 2003 | 10:50 AM
NovaKaw650's Avatar
You said "leak". Does that mean the oil level is actually going down? Or is the oil in the airbox the only symptom? If it's the latter, the cause is probably what newbeatle said: too much oil.
Old Jun 5, 2003 | 01:16 PM
Raybourque's Avatar
Hey thanks for such quick response. Anyways, there was oil in the airbox so it could be a simple thing as to much oil. I will have the owner check his bikes oil level. NovaKaw650, there also was oil on the ground so I am not sure if the oil in the airbox found a way out. Anways thank you for all your help.
Old Jun 5, 2003 | 06:54 PM
Kawi650's Avatar
Yes the oil will find a way out of the airbox on a 400. When you ride a long time I seen a 400 that if you open your oil dipstick after a run it would bubble out of the dipstick hole does yours? What oil are you running?
Old Jun 6, 2003 | 05:50 AM
rivermud's Avatar
Raybourque, It is most likely the simple matter of overfilling like newbeatle and novakaw650 say.
If you find it doesnt solve the problem do a search for a post I made called "oil in airbox solution (cheap mod) " posted on may 13th this will fix the symtom if not the problem.
Old Jun 7, 2003 | 02:03 PM
400PrarieXLT's Avatar
Yes overfilling will cause that, mine has done it a time or two. If I ride all day and then pull the dipstick, sometimes it will bubble out. Even when I know its not overfull. Guess its the nature of the beast.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
jsmit116
Sep 18, 2015 10:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
chewy78
Sep 8, 2015 10:37 AM
