Vforce toe in??
Old Jun 7, 2003 | 12:09 PM
Ryanstones's Avatar
Default Vforce toe in??
i'm replacing my V's steering stem today and want to check the alignment/toe. Does anyone have any suggestions for the ideal toe in?
My son rolled my 2 monthold V into a 5' wide, 6'deep gully. It landed flat on the seat/handlebars and bent the stem. I think the upper frame bent a little at the stem bushing block. Get out the sledgehammer. other than that she only suffered 2-3 plastic mounting bracket cracks. amazing! Man was it tough to turn this beast over in that gully! The boy was unharmed until i got the quad out of the hole. then....no J/K.
Thanks!
Old Jun 7, 2003 | 12:57 PM
2lman's Avatar
I set mine to zero toe-in after my wipeout, and it rides straight. If you thought it was tough flipping it in that gully, try doing it with your freshly separated shoulder. I was pretty impressed with how the V took that crash. I managed to bend the brackets back into place and only had to order a couple that were bent too bad. The bracket right above the muffler bent down and actually dented the muffler. It's good to go, but I'm still pretty sore.
Old Jun 7, 2003 | 02:38 PM
Ryanstones's Avatar
Thanks 21man. I could not have flipped it back over with that shoulder, impossible. I'm fairly impressed at how well it took the crash too. I've got 5 cracked/broken mounting points on the plastic, but they'll still work and it's not bad enough to replace. Visually, it really doesn't even show!? Dealer told me $300 for front/rear fenders.
Kawi sent me the correct # stem, but it sure aint a Vforce stem! Must be from a prairie. Now i'll wait 2 more weeks i guess. Thank goodness for a back up quad!
Hope you get feelin better soon!
Polaris-400
Aug 19, 2015 02:20 AM
brewster2003
Jun 23, 2003 09:45 AM
Lifesun
May 28, 2003 04:18 PM
DirtDragon
May 12, 2003 02:54 PM
