400ex 22in tires
my friend keeps telling me not to get maxxis all traks becasue they are 22s but im sick of gettin hung up all the time becasue of my ground clearance is the 400ex tippy with the 22. Can you really tell a difference with them thanks tell me iif i should get them or just stay with 20s
13 tooth is a little too low of gearing, unless you like to just crawl around. I have a 14 tooth front, and it is great for the dunes and tight trails, but when you get to a wide open spot, you really want that top speed (that you will lose) back. You're not going to notice that much of a difference with the 22" tires. I say buy them, try them out, and if they bog your motor down, then change your gearing a little bit. I currently run 21" sand tires with a 14 tooth sprocket, and I've got power to spare, so I'm thinking you'd be fine...especially if you plan on adding a pipe, air filter, etc...
My brother tried a set of 22" shredders with stock gearing and a k&N power kit. He didn't like them though because they were to heavy and caused it to handle poorly. He didn't notice that much of a power loss but he did notice an increase in top speed. After a couple weeks he put his 20" razors back on.
