400ex 22in tires
Old Jun 7, 2003 | 05:16 PM
hannahj's Avatar
Default 400ex 22in tires
my friend keeps telling me not to get maxxis all traks becasue they are 22s but im sick of gettin hung up all the time becasue of my ground clearance is the 400ex tippy with the 22. Can you really tell a difference with them thanks tell me iif i should get them or just stay with 20s
Old Jun 7, 2003 | 05:18 PM
scrambler123's Avatar
you will notice a difference but if you add 2 teeth on the back sprocket it will feel the same but have more clearance. I dont think it will be tippy
Old Jun 7, 2003 | 05:37 PM
sickmojave's Avatar
will it pull the 22's with out changing the sprockets? seems like the stock gearing is low enought to pull them with no trouble.
Old Jun 7, 2003 | 06:20 PM
CrAcKhEaD's Avatar
its always better to change the sprokets, b-sides the 400 is kinda low on power so im pretty sure it'll struggle with stock gearing
Old Jun 7, 2003 | 07:31 PM
sickmojave's Avatar
ok thanks I wasn't sure. I.m thinking of using 22's when I get mine.
Old Jun 8, 2003 | 12:22 PM
NotuRaptor2's Avatar
Get a 13 tooth front for running with 22" tires especially in the mountain of WV. Seen them on e-bay for under $15 many times.
/Jon
Old Jun 8, 2003 | 12:48 PM
chad400ex's Avatar
13 tooth is a little too low of gearing, unless you like to just crawl around. I have a 14 tooth front, and it is great for the dunes and tight trails, but when you get to a wide open spot, you really want that top speed (that you will lose) back. You're not going to notice that much of a difference with the 22" tires. I say buy them, try them out, and if they bog your motor down, then change your gearing a little bit. I currently run 21" sand tires with a 14 tooth sprocket, and I've got power to spare, so I'm thinking you'd be fine...especially if you plan on adding a pipe, air filter, etc...
Old Jun 8, 2003 | 02:56 PM
01redrecon's Avatar
My brother tried a set of 22" shredders with stock gearing and a k&N power kit. He didn't like them though because they were to heavy and caused it to handle poorly. He didn't notice that much of a power loss but he did notice an increase in top speed. After a couple weeks he put his 20" razors back on.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
