Are clutch kits hard?
Old Jun 7, 2003 | 11:07 PM
dirtripper1's Avatar
Default Are clutch kits hard?
are clutch kits hard to put in? thanx again
Old Jun 7, 2003 | 11:22 PM
2manytoys's Avatar
The only thing hard about the kits is doing the secondary clutch. If you have never done one then it can be frustrating. Just trying to get the spring wound right and knowing what position to put it in. Everything else is easy. If you need help just ask Im sure someone will help you at that time.
Old Jun 7, 2003 | 11:41 PM
scrambler123's Avatar
clutch kits are very easy to install i changed mine by myself in about a half hour the first time i did it easy to follow instruction come with it.
Old Jun 8, 2003 | 01:45 AM
naturalite's Avatar
Its easy. I dont know about half an hour by my self but I did it in about that with help. and that was winding the 2nd clutch. But you do need the cluth removers. The gain was great, expecialy when I ported the motor.
Old Jun 8, 2003 | 01:48 AM
i did not need any clutch removers dont waste your money
i'm not that skilled of a mechanic and i did it easily with normal tools
Old Jun 8, 2003 | 09:40 AM
naturalite's Avatar
How did you remove the clutches from the motor and tranny? I heard you shouldnt try to pry them off you had to use the clutch removers to keep from damageing them? Teach me something new.
Old Jun 8, 2003 | 12:17 PM
Farmr123's Avatar
If the kit consists of weights/spring for the primary clutch, they can be replaced with the clutch on the machine. The secondary clutch must be removed for access to the helix/spring, but I would say over 90% of them come off with a strong tug by hand, no pullers needed.
Farmr
Old Jun 8, 2003 | 02:07 PM
TrailBlazerguy250's Avatar
Cummins Driver
Sep 11, 2019 01:22 PM
robert301972robert
Aug 30, 2015 11:34 AM
toonces
Aug 5, 2015 05:55 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Mikesohio
Jul 26, 2015 10:51 AM
