Top Manfold bolt.
Old Jun 8, 2003 | 12:05 AM
MudStud's Avatar
Default Top Manfold bolt.
How can I get that dang thing out?
I have a 5mm alan witht the ball on the end but it slips out.. Then I bougt a T handle kit and the dang thing inside are not the right size.. it says 5 but its like a 4.5...
Its the TOP bolt under the motor mount.
Old Jun 8, 2003 | 12:20 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Hey bud are you sure you did not split the head on the allen with the frist one and thats whats making the second seem small ?? i hate to bring that up but it dose sound like the likley problem???
Old Jun 8, 2003 | 12:34 AM
MudStud's Avatar
no...
None of the head are split on the 5mm sticks or the bolt... All of those crappy T handles ones I got are out of spec.. They are the $7 set from menards.. but I figured they would be IN spec!!!.. bolt is intact..
Old Jun 8, 2003 | 12:42 AM
AZSAND's Avatar
They are very hard to get out infact it sounds like there breaking every time i losen one up !! but good luck any way's
Old Jun 8, 2003 | 12:45 AM
Oldmanracing's Avatar
If you have the two outside bolts first removed then,
using a plastic hammer or piece of wood, tap on the lower right side of manifold
to turn the whole manifold counterclockwise. Have the ballnose allen in the bolt at the same time
and this will break the bolt loose. The factory seems to use locktite during assemble.
Once you can get even a 1/8 turn the bolt will start to turn easily.
Old Jun 8, 2003 | 10:21 AM
DDrecDS's Avatar
I bent one so it would line up better and go in deeper.
Old Jun 8, 2003 | 07:54 PM
Eaglecollector's Avatar
The way Oldmanracing said is the exact same way I did it the first go around. In fact, thats what the direction said to do that cam with my manifold from RWR.
Shifts
Jul 3, 2015 07:59 AM
BigDaddy331
Dec 2, 2003 12:20 AM
BigBadScrambler
Nov 5, 2003 09:09 AM
TheRaptorMan
Apr 2, 2003 08:42 PM
trout
KTM
Jun 6, 2002 03:18 PM
