HPD Race pipe/Ignition timing
Old Jun 9, 2003 | 10:58 AM
401's Avatar
401
Default HPD Race pipe/Ignition timing
What is the proper way to set the timing on a 400 scrammy?At what degree(s) do you set it at?Soon to have back all my parts from HPD/Rick Ritter.I have read on the forum about this before with this HPD race pipe. Thanks in advance.
Old Jun 9, 2003 | 11:22 AM
CED's Avatar
CED
It needs to be retarded 2 degrees,or counter clockwise1/8 of an inch.
Old Jun 9, 2003 | 05:13 PM
modquad's Avatar
Along with the spec CED gave, be sure to note, the timing is set/checked with the engine at 3,000 rpm. If you're gonna get your flywheel shaved, best to change/check timing first. If you don't, the most accurate way to re-index it is with a small diameter degree wheel.
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Robinhood
Jul 13, 2015 09:13 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:43 PM
