some axle help please??
Old Jun 10, 2003 | 12:38 AM
brad650's Avatar
Default some axle help please??
ok, so i got my wheel hub off and the lock nut, got all the little washers and clip off, the rotor and hub slid some, but i cant get it to slide it all the way off. is it sposed to or what?? i know that after i get the rotor and hub off it slides to the right? tell me if im wrong... help!
brad
Old Jun 10, 2003 | 01:16 AM
DaSandBomb's Avatar
I know when I replaced the rear Bearings on my 2000 DS I had to use a floor press to get the thing off. Went back on much easier. I've read that some guy's just use a wooden block and a big hammer to beat the thing off. You might search thru the old listing for more info.
By the way, the same bearings and seals can be purchased at any bearing shop or even NAPA cheaper than at the dealer.
Hope this helps.
Old Jun 10, 2003 | 01:23 AM
brad650's Avatar
so do you have to take the disc off to get that disc hub off? and your sure you beat it to get it off? it slides easy on the toothed part of the axle next to the carrier, but in one spot it just stops... so i just hit it off?
thanks! [img]i/expressions/face-icon-small-smile.gif[/img] brad
Old Jun 10, 2003 | 01:34 AM
jiminok's Avatar
There's an O-ring inside the hub that is hitting the flared/tapered part of the axel when you try to remove it...I just yanked it off the axel once I got to the point your at. Check the O-ring for damage before you reasemble...
Jim
Old Jun 10, 2003 | 02:47 PM
brad650's Avatar
alright i got her apart... thanks guys
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
