Fan still running???
Old Jun 11, 2003 | 01:07 AM
BabyMoose's Avatar
Default Fan still running???
Just got my new V force delivered today and took it for a break in ride. It is totally different then my DS, but one puzzling question. The fan kicked on and ran, but when I shut the motor down and took the key out the fan still ran. Is this normal???
Thanks!!!
Old Jun 11, 2003 | 01:10 AM
cvkp650's Avatar
It's perfectly normal, the engine may not be running but the heat is still there, it just helps cool it down faster. Congrats on the new ride, have fun and ride safe....
Old Jun 11, 2003 | 01:23 AM
BabyMoose's Avatar
But is it still suppose to run after you take the key out???
Old Jun 11, 2003 | 01:27 AM
BigOne's Avatar
Yes, If it still hot it will run untill it gets the temp down.
If it doesnt shut of then you might have a bad temp sensor, Mine was bad it just keeped on running the fans even when dead cold.
Old Jun 11, 2003 | 01:36 AM
BabyMoose's Avatar
Well that kinda sucks! How hard is that on the battery???
Old Jun 11, 2003 | 02:11 AM
cvkp650's Avatar
If it runs continually after the motor is cool you might have a problem, otherwise it will quit running when the motor is cool enough. I rode mine for a while tonight and after i shut it off(and took the key out of the ignition) the fan still kicked on a couple of times.
Old Jun 11, 2003 | 02:13 AM
BabyMoose's Avatar
Thanks for the info, I just felt like that was really odd.
Old Jun 11, 2003 | 02:22 AM
cvkp650's Avatar
They do make some additives you can put in your radiator (can't remember the names right now) they will make your ride run a little cooler and the fan won't come on as much or so i've heard. do a search on the forum and you should find out more info..
Old Jun 11, 2003 | 05:50 AM
rivermud's Avatar
Water wetter, purple ice, 40 below, DEI radiator relief, and there is another product I cant remember off hand that was the cheapest, It was at autozone, $5.86 for a 12 ounce bottle (more than you need).
Its not hard on your battery and good for your engine. The prairies do the same thing.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
