Just installed High Lifters Lift Kit on my P650>>
Old Jun 11, 2003 | 05:03 AM
lackdog's Avatar
Default Just installed High Lifters Lift Kit on my P650>>
Sup all I just put on a High Lifter Lift kit on My p650. Looks way more tuff now! I was wondering if anyone has the same kit and if it causes any problems? Thanks
Old Jun 11, 2003 | 06:53 AM
Scotia650's Avatar
Had mine installed for almost a year now and no problems yet. It might increase wear on the front joints and boots because of the greater angle on the shafts but not enough to concern me. What size 589's are you running? My 28's on the c-series with the lift really looks aggressive, I love it!!!
Old Jun 12, 2003 | 11:03 PM
650forme's Avatar
does your bike have a lean spot with that dynojet kit
Old Jun 12, 2003 | 11:13 PM
NovaKaw650's Avatar
Mylen, I could never get my Dyno Jet kit to work properly. Did you get the HMF on and are you ready for Saturday?
Old Jun 13, 2003 | 01:27 AM
Not2Old2ATV's Avatar
May be just my poor luck,,installed H/L kit in Dec 2001, replaced left frt inner drive axle seal "2" times the following year. When I noticed it had started leaking "again", removed the kit,, no more oil leakage. This was aprox 3 months ago.
Old Jun 13, 2003 | 06:33 PM
650forme's Avatar
i got the pipe on, but have a lean spot around 37 - 40 , i was ready but the ir won't stop raining[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jun 13, 2003 | 07:57 PM
NovaKaw650's Avatar
Don't sweat it for now - you won't get up that much speed in the Exhibition ring.
Old Jun 14, 2003 | 01:08 PM
ChaosInMt's Avatar
Why did you put it on ? Did your tires rub ? What did you gain other than higher center of gravity loss of handeling and more stress on the joints and seals? I gess I just dont get it.
Old Jun 14, 2003 | 02:35 PM
Scotia650's Avatar
650forme,
I don't seem to have a lean spot anywhere. Bike starts well and pulls hard all the way up.
ChaosInMt,
More ground clearance. Better clearance for 28" 589's. Also more beefier look. As I said earlier, no problems yet but I quess time will tell.
Old Jun 15, 2003 | 12:41 PM
650forme's Avatar
what clip setting do you have it set on the needle, is there a pull in digby soon if so could you tell where it is at , thanks mylen
