three wheel drive
Old Jun 11, 2003 | 11:36 PM
brayden's Avatar
Default three wheel drive
my right front wheel quit pulling on my 2000 sp500 ho. how do you check the mag? shortly after i bought it new. the bearings went out in the right front. factory didnt put a cotter key in the lock nut. nut tightened up, got hot, burned the seals, lost the oil. dealer made it good but dont think they checked everything while apart. anyway is there an easy way to check the mag. thanks
Old Jun 12, 2003 | 12:09 AM
Traildog's Avatar
One of the more common 4WD failures is broken wires going to the hub coil.
Old Jun 13, 2003 | 02:05 AM
03P360's Avatar
A friend of mine had this happen on a scrambler. Check the funny looking washer that sits next to the mag. His was barely bent, I mean you could hardly tell but it was enough to make only one front spin.
Old Jun 13, 2003 | 04:52 PM
lovemud's Avatar
Do a search on hubs, I've seen a few good posts recently on this subject.
Old Jun 13, 2003 | 04:57 PM
Traildog's Avatar
03P360, that funny washer you mentioned is the armature plate and you are absolutely correct, the tolerance is 0.0015". The positioning of the plate is critical to the operation of the AWD system.
Old Jun 13, 2003 | 07:41 PM
highwayman's Avatar
Local Mech once showed me how the AW Drive worked and he just turned the ignition on put in gear and engaged the AWD the funny washer stuck to the roller cage.Don't know if this is what you were looking for but if it helps, great.
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
toonces
Aug 5, 2015 05:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
