Need Help With Erlandson Scrambler Clutch
Old Jun 12, 2003 | 01:21 AM
scramblurred's Avatar
Default Need Help With Erlandson Scrambler Clutch
I just bought a bunch of stuff for my scrambler 500 4x4. I installed the erlandson sport utility clutch kit successfully. I set it on what the directions said to do on the secondary pully. It said to put the spring on the 2nd hole of the helix and the third on the pully. However the performance was horrible. On take off a bicycle could beat me, and it the belt would slip and make a grinding noise. However after experimenting with it every thing works great on the system by putting the spring in the first hole on the helix and the third on the pully. I just want to know if anybody else has had this problem and what setting they use. Also need to know if the diff. size sprocket would effect the 4wd and why im leaking gas out of the bottom hose on carb. Also need tips on installing jets.
2000 Polaris 500 4x4 w/ uni air filter, dyno jet kit, erlandson brakes, erlandson s/u clutch kit, sunstar sprockets(13,30) and srx ek racing chain
Old Jun 12, 2003 | 11:13 AM
scramblered's Avatar
it is because the stiffer the spring's pulley is,the more the belt will slip,but you'll get better upshifting,while the spring is softer,it will
slip less and better backshifting.
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
