700 with leaking beltcase
Old Jun 12, 2003 | 10:04 PM
dillian's Avatar
Default 700 with leaking beltcase
guys i removed the air intake of the beltcase and filled it with water and found the leak, it was behind primary clutch ... the dealer told me the the gaskets were made of felt..is this true ? so what do i need to remove the clutches??
Old Jun 13, 2003 | 10:09 AM
LaMudd's Avatar
I had a leak behind the primary clutch also...felt gasket? Mine is rubber. You can feel/see it on the backside of your clutch. We just took the clutch cover off, removed the belt, removed the bolt for the clutch (I went to the store, and when I came back entire clutch was off) removed rubber seal. Cleaned everything real good, I used 3m marine grade adhesive, fast cure, put around the seal put the seal back in, reattached everything. I put a new gasket around the belt housing and sealed the belt housing also. I have no leak now.
I hope this helps some. Be careful to pay close attention the order you remove everything, mark the way everything is lined up before you remove so you can place back exactly like it was. Even on the seal.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
