is it possable!
Old Jun 16, 2003 | 11:31 AM
turd's Avatar
Default is it possable!
i have a 01recon and i need to no wat mods i can get for it. i need to in crease the hp and speed.
01 recon
01 90 scrambler
03 z400with few mods
no mud no fun get down and dirty
Old Jun 16, 2003 | 11:37 AM
DirtDiggler's Avatar
Pipe, filter and rejet for starters. I think the recon is shaft drive so the only way to gear it higher is with larger tires. The increase in HP should make up for the drive train having to turn larger tires. If you have decent mechanical skills you can put a higher compression piston and a cam (4 stroke tech) has them. The only problem is if you did all that you would find the limits of the stock suspension really fast. Big hp increases are great for drag racing or getting it to turn bigger wheels in the mud or something like that but if you want to be faster everywhere get suspension. From now on I'm always going to do suspension first.
Ice tester
Jun 22, 2013 08:58 AM
mudslinginfool
11
Apr 4, 2009 07:50 AM
chuck_raduenz
Mar 24, 2009 06:51 AM
Nobody077
Mar 5, 2004 12:42 PM
dsracer666
May 16, 2003 06:14 PM
