new to boars got some questions about trail blazer 250
Old Jun 17, 2003 | 04:40 PM
hebear's Avatar
Default new to boars got some questions about trail blazer 250
hey guys i just bought a trail blazer the piston was cracked and i replaced it i put a hot seat pipe on and jetted it to 150 when i have it at full throtle it wants to bog do i need a clutch kit
Old Jun 17, 2003 | 05:03 PM
Polaris69's Avatar
I stuck the 150 jet it and it would bog down and die. i stuck the 140 in and it runs fine. try that maybe?
Old Jun 17, 2003 | 05:07 PM
CED's Avatar
CED
What your bog is telling you is that you are either too rich or too lean.You have to do some plug checks at 1/4 throttle 1/2 and full.You need to run the bike for a couple minutes then do these checks.Make sure you hold your throttle at these different positions then hit the kill switch by your left hand.Check your plug and these readings will tell you why your bog is there.The perfect plug color would be paper bag brown, a white porcelain would mean it is too lean,and a black color would indicate too rich.Get your jetting right then you can check into a clutch kit to get the most power out of your pipe and get it to the ground.Hope this helps.
Old Jun 17, 2003 | 09:52 PM
2manytoys's Avatar
Did you buy the pipe from hotseat and is that the jet that they sent or is it used and you are guessing on the jet size. Hotseat pipes will go up 1 full jet size without anyother mods. Most likely it is to rich. You can also open the airscrew a little bit to see if it changes.
Old Jun 17, 2003 | 10:34 PM
hebear's Avatar
thanks for the advice no i asked a guy at the polaris dealer what jet to put in it he said maybe a 160 to a 150 i bought the pipe when i bought the trailblazer it came with it. My plug is really black so i guese i am running rich. Is that the size jet i should have in it and if not what should i have thanks for all the help im new to all this
Old Jun 17, 2003 | 10:42 PM
2manytoys's Avatar
Ok the plug is really black so yess it is rich. Your stock jet is 135. Get a 140 and it should be ok.
Cole Hadden
Jun 15, 2025 09:05 AM
coolguy420
Jul 28, 2015 01:54 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Gnuters
Jul 19, 2015 10:03 AM
yambam13
Jul 4, 2015 01:49 PM
