speed
Old Jun 22, 2003 | 04:34 PM
prairieridr650's Avatar
Default speed
How can I get more speed on a prarie? Will smaller tires work? why or why not?
Old Jun 22, 2003 | 04:43 PM
ElectricShift's Avatar
Default speed
You got it all wrong, smaller tires will get you more torque, bigger tires and you will lose a little bit of torque and gain a little speed.
Old Jun 23, 2003 | 07:09 AM
AJ650's Avatar
Default speed
But larger tires add weight. Increasing tire size raises the final gear ratio (lower numerically) and SHOULD give the bike a little longer leg so to speak. But the main limitation in speed is and will be the CDI. Proper tuning and a few basic mods will give you a little more top end. Some mods give better bottom end, but will/can detract from the top end. The black spring is 1 of these. Generally makes the bike livelier on the bottom end, but some report losing a little on the top. I did a couple minor mods at the same time as the spring, picked up a butt load of midrange fun, and still picked up 1mph on the top. A couple more mods should net a couple more on the top, but the midrange power is a lot more fun to play with. If the top end modules or CDI is ever released, you should be able to pick up another 5-10 mph (guessing). Do a search, you'll get lots of info.
Old Jun 30, 2003 | 07:28 PM
Default speed
then why do smaller tires make 2-strokes go faster?
Old Jul 1, 2003 | 01:11 AM
mahnster's Avatar
Default speed
its the same for 2 strokes and 4 strokes
Old Jul 8, 2003 | 02:50 PM
Default speed
What will my top speed be with 20 in. tires? What about 18's?
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
