Works Triple Rates
Old May 13, 2000 | 12:00 PM
Y2K300EX's Avatar
Do you think that these would be good front shocks to put on a 300ex?
Old May 13, 2000 | 12:12 PM
BlueBlaster's Avatar
Works are excellent shocks, but unless you plan on racing you really only need dual rates. When I get new shocks I am going to get double rates for two reasons. 1 they are less expensive than triple rates and 2 I don't need any thing better than the double rates.
Old May 13, 2000 | 12:39 PM
hakmazter's Avatar
You can't really get triples for a 300ex. I have a friend who had Last rebel make some for his 300ex. Works had to remake them with a lot of resistance. They said there is not enough shock travel for a 300ex. Good luck, but the duals are fine.
Old May 13, 2000 | 12:44 PM
Y2K300EX's Avatar
Actually you can order them from www.shocconnection.com. They are $339 w/o rezzy's.
Old May 15, 2000 | 07:54 PM
Y2K300EX's Avatar
Any more opinions?
Old May 15, 2000 | 08:45 PM
hondatrx300ex's Avatar
instead of gettin triples with out rezzy's get duals with rezzy's.I have duals with out reservoirs and they work real good.
Old May 15, 2000 | 09:48 PM
Dill's Avatar
I disagree..unless you are a hardcore mx racer, stick with the triple rates w/o rezzy..most people would be tired out before the benefit of rezzies comes into affect (keeping the oil cool) and the triple rate spring is worth it..
Old May 16, 2000 | 01:24 PM
86atc250r's Avatar
Or spend a little more money and get TCS's, they will ride smoother than stock and take the hard hits better as well.... Mine are setup for the +2 control arms that I don't have yet and still ride far better than stock. The difference is amazing.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
