Cleaning 4 wheeler.
Old Jun 28, 2003 | 11:24 AM
de8212's Avatar
Default Cleaning 4 wheeler.
Haven't cleaned my 4 wheeler yet so I think it's about time. I skimmed over the manual when I first got it and I'll break it out later today to refresh my memory. Just curious if anyone has any tips on cleaning thiers?
Any info is appreciated.
ALso I have seen ATV stands for working on them (or cleaning). What kind do you all use, if any?
I have a pretty sturdy plastic crate but I haven't tested it out to see if it will hold the atv. Actually I'm not even sure if I can lift it.
BTW this is a 2003 yamaha warrior.
Old Jun 28, 2003 | 11:29 AM
RookWV's Avatar
Just soap and water, like a car, keep water out of the exhaust...and then follow up with some Formula2001 or something to make it shine and help it come clean the next time.
More info
Old Jun 28, 2003 | 11:46 AM
de8212's Avatar
ty rook.
How about the chain/sproket? I htink the manual said my chain has O rings and should be removed. How do you take it off? What do you clean the chain with? I already bought some ChainLube.
Old Jun 28, 2003 | 12:58 PM
RookWV's Avatar
Just scrub the chain with a medium stiff NYLON brush and soapy water....Don't use a wire brush, no need to take the chain off unless it's so mucked up that a soaking is all that'll get it clean....then blow it dry or some use WD40 and then warm the chain by riding for 10 minutes or so and the lube it up.
Old Jun 28, 2003 | 02:57 PM
whatwasthat's Avatar
dont put any wd40 on the chain, it will eat the orings and basically ruin your chain
Old Jun 28, 2003 | 05:55 PM
RookWV's Avatar
I've heard differing opinions on the WD40, I don't use it because I don't know....I just clean the chain and use some ChainWax
Old Jun 29, 2003 | 08:14 PM
badprairie's Avatar
I have a rubber cork with a screw in it that I put in my exhaust it works a lot better then a bag because you can wash what the bag would be covering. Just rember to take it out before you start it!
Old Jul 1, 2003 | 02:00 AM
snowbuster's Avatar
simlegreen for the plastic. for any black plastic use armoral, not sure thats how its spelt out!
Cole Hadden
Jun 15, 2025 09:05 AM
WilliamBos
Aug 8, 2015 07:26 PM
WilliamBos
Jul 25, 2015 02:41 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
coldnorthpol
Jul 14, 2015 11:22 PM
