300EX won't start?
Old Jan 28, 2000 | 02:05 PM
DG_300EX's Avatar
I am having a problem starting my 300EX I have check to see if the spark plug sparks and it does and there is gas in the tank and the kill swich ins't on and it is starting to bother me
it happended right after i gave it a wash and it is winter so i was wondering if anyone has had a simliar problem with freezing etc
if anyone has any ideas
E-mail me at: winky@netrover.com
or
icq uin:43170971
or post your reply in the fourm
Old Jan 28, 2000 | 03:48 PM
thomas's Avatar
dg 300ex, maybe your fuel line froze, but i should not of unless you got water in your gas. Try some dry gas maybe to see if that helps. Hope it works for you.
Old Jan 28, 2000 | 05:54 PM
250Thumper's Avatar
if he had water in the gas it would start, just miss alot. that happend to me once.
Old Jan 28, 2000 | 08:44 PM
quad_300ex's Avatar
I have a 2000 300ex and today I went out gonig to ride and it wouldn't idle not that it ever does and it make me so mad when it does this, What I do is when mine won't start I Hold it about half to quarter throttle and hold down the starter till it starts, about 5 seconds or so. Hope this help!
Old Jan 28, 2000 | 09:05 PM
JB_450s's Avatar
We had a similar problem on a sportsman 400 last weekend. We found that the gas line to the carb would barely drip out fuel. Spent an hour trying to figure it out because it had strong spark. It would fire a little and then shut off because it ran out of fuel. Not wanting to cancel or delay our ride any longer we took (believe it or not) handwarmers (that heat up when you open them up) put them on the bottom of the tank and thawed the line. Then we drove it to the gas station and dumped a bottle of isoheet in it. It ran fine the rest of the day.
Old Jan 30, 2000 | 06:36 PM
DG_300EX's Avatar
I fixed it last night all it was, was some water i the carb because i just cleaned it and the hot water on the carb created condenstaion and kaboom water apeared any way it runs as good as ever now THANKS
DG_300EX
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
Hondaislife
May 28, 2015 01:43 PM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
