Antifreeze in the counterbalance
Old Jul 5, 2003 | 09:55 PM
ftwflh's Avatar
Default Antifreeze in the counterbalance
How much trouble will I have replacing the seals?Any input will help I have never had to do this.
Old Jul 6, 2003 | 01:18 AM
modquad's Avatar
It's not a bad job. The two seals look almost the same, except one has an additional lip. You also have to take into consideration if the counterbalancer shaft has enough of a groove worn in it...just changing the seals might not do it. There are some place to get it repaired, cause a new one is over $300 as I remember.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
JohnnySplat
Aug 6, 2015 12:07 PM
sks762
Nov 1, 2000 07:06 AM
cstark
Sep 11, 1999 01:21 AM
