SP500HO - Whine ??
Old Jul 6, 2003 | 07:36 PM
tk1469's Avatar
Default SP500HO - Whine ??
I have a SP500HO with very few miles/hrs (only 2nd tank of gas). Today after riding it harder than usual - I now hear a slight "whine" coming from (what seems like) the rear of machine. The sound of the "whine" doesn't change with speed or whether in HI or LO - anybody know anything about this ?? Is this normal?? A few friends say it's OK, but being a first time Polaris owner - I'd like to get you guys "expert opinions".
Old Jul 6, 2003 | 07:45 PM
icrashalot's Avatar
you didnt bend the exaust outlet did you? ive heard a whisle com,e from a bent exaust outlet. a friend backed into something and damaged his outlet pipe. prob. not but is an idea
Old Jul 6, 2003 | 08:31 PM
hemihead's Avatar
Try some trouble shooting, IE: does it do it in neutral, does it change "pitch" with rpm, try rolling down a hill in neutral (engine off) see if it is the chassis or wheels are making the noise. Good luck & hope its not a major prob.
Old Jul 8, 2003 | 05:35 PM
tk1469's Avatar
Yea - sure I didn't bend the exhaust pipe. I looked the machine over good - nothing visibly bent, broken, or otherwise unusual. Dealer says it might be a clutch - I'll take it over there soon to have him check it out.
Old Jul 8, 2003 | 05:40 PM
401's Avatar
401
Not to worry,mine does the same thing when in low range and you let off the gas.It's normal.That's the EBS system that you are hearing.
Old Jul 8, 2003 | 05:45 PM
tk1469's Avatar
Mine does it in low range with throttle pressed - steady slight whine ... Dealer will check it out soon.
Old Jul 8, 2003 | 05:58 PM
401's Avatar
401
Now that you mention it mine also does it,but only in low gear.Kinda like a old car or truck when you put it reverse it makes that noise when you back-up.
Old Jul 9, 2003 | 08:12 AM
tk1469's Avatar
Yea - exactly. That's the sound - like a car backing up. Probably normal - but I'll take it in just to be sure - since the warranty is still in effect...
Old Jul 10, 2003 | 09:55 PM
hotdog's Avatar
I have had the same whine in mine..been there since I bought it little over a year...it's a 2002..someone said it could be the back brake..but i don't think...it no worse now then it ever was..so I don't think it's anything to worry about
Old Jan 19, 2005 | 04:17 AM
sirphishalot's Avatar
yup...my sp500ho has made that noise since day one.
