big bear front end question
Old Jul 8, 2003 | 08:20 PM
Ilovemymudder's Avatar
Default big bear front end question
I have a 2000 big bear 4x4
I am replacing the bearings and have been unable to remove the knuckle without much success - I have removed the tie rod, nut and cotter pin - I have removed the other two nuts and cotter pins from the knuckle - top and bottom - (this is at the end of the A Arms) - then removed both cir-clips from the tops of the joint -
it should be easy to remove them - but they wont budge - I have tried liquid wrench - I have tried a little heat - I have beat the crap outta them, but nothing.
These are the joints that hold the knuckle to the a arm - a little rubber boot is there - is there another nut that I have missed? What am I doing wrong?
BTW - I am hitting the joints from the bottom (where the nut and cotter pin is)
Is it possible I need to drive them down from the top?
Any help is appreciated
Gary C
Old Jul 8, 2003 | 09:37 PM
I think the joints are located on the spindle
3quadbob
Sep 18, 2016 09:46 PM
bonanza 440
Jun 26, 2015 10:01 PM
scaldwellk
Jun 19, 2015 05:08 PM
hoopduerr
Jun 2, 2015 09:01 AM
Biggieshortie89
May 26, 2015 08:01 AM
