Needle jet adjustment
Old May 17, 2000 | 11:41 AM
RoostKing's Avatar
Gents,
When do you guys ever mess with the needle jet? I just bought FMF/power cores with boyesen reeds, reed spacer, K&N, and installed the 260 mains that were sent. I am at close to 6000 ft. in altitude and it is rich. I was told that all major jetting changes should be done with the needle jet first, then fine tune with mains. What do you KNOWLEDGABLE people say? I am going to be running with the airbox lid on, but with about 10 1 inch holes in it for the dunes..
RoostKing...
Old May 17, 2000 | 01:43 PM
fakie99's Avatar
roost:
in my experience, it's the other way around. with the main jet supplying fuel at the upper half roughly of the rpm range, i would think the mains would provide the most significant jetting change opportunities. then fine tuning at the other rpm ranges could be accomplished by changing the height of the needle, needle jet number and pilot jet.
i have generally stayed with the pipe manufacturers jetting recommendations. if you are still rich, try a step down on the main...
Old May 17, 2000 | 01:57 PM
MDP49's Avatar
Which part do you adjust to increase fuel on the low end?
Old May 17, 2000 | 02:27 PM
fakie99's Avatar
on my two-stroke snowmobile, low rpm fuel delivery was increased by increasing the size of the pilot jet. i assume it's pretty close in an atv application...
Old May 17, 2000 | 02:33 PM
99blueblaster's Avatar
-Air mixture screw for idle
-Pilot jet from idle to 1/4 throttle
-Jet needle for 1/4 to 3/4
-Main will effect from about 1/2 to full
Set the idle first so that it will idle fine. Next you need to set the main. To do this run it wide open if 5th gear for about 1/4 mile then pull in the clutch and shut off the engine and coast to a stop. Pull the plug and do a read. White way down inside is lean, black/oily is rich. What you are looking for is a coffee brown color. On a new plug it should be barely noticeble. If there is a wet ring you are going to be rich. Remember to read from way down inside not the nose of the plug. Now once you have that right set the needle. If bogs and misses like the choke is on at 1/2 throttle your rich. If you here it pinging or is weak at accelerating your lean. A nice long hill that you can climb at half throttle works good for this. You will know if your rich easily, lean you must listen to the motor closely.
No two quads are the same and must be jetted for max performance.
Old May 20, 2000 | 12:55 PM
thumper4x4's Avatar
99BlueBlaster is right on..
You first need to set the pilot circuit/or idle.
The reason is this flow is always on, so it will slightly affect everything else you do.
Depending on where you live, and what kind of fuel you run. Reading plugs can be a little difficult. Im in the SF Bay Area and the fuel out here is junk and very hard to read on a plug...
I have found 3rd gear on a slight incline or hill. Bog the motor a little, then open the throttle all the way, Its a good test for checking a rich condition, if your rich it will bog pretty bad.
Hope this helps...
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 24, 2015 03:39 PM
