scrambler brake fluid leak
Old Jul 14, 2003 | 11:29 PM
scramblazer400's Avatar
Default scrambler brake fluid leak
My 98 400 has been down for a couple weeks for a broken piston (supprise supprise). Now I went to move it and the brake lever went to the bars and the fluid is running out past the lower cylinder reservoir cap and you can see the cap pulsing when you pull the lever and you also can see the rear brake pads slightly.
any ideas ??
Thanks
Old Jul 15, 2003 | 01:15 AM
OffRder15's Avatar
If I understand you correctly, it sounds exactly like the symptoms of a blown seal in the rear caliper, usually caused by letting the pads wear down too far.
Old Jul 15, 2003 | 08:29 AM
N.Y.scrambler's Avatar
same quad, same problem. I just finished repairing the same prob. Like offrder said its the rear caliper seals and or the pads are worn too much. good luck.
Stirling
Aug 9, 2015 01:49 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
DeFox500
Jul 26, 2015 06:32 PM
Sandman2.0
Jul 21, 2015 09:03 AM
rcappie4
Jul 10, 2015 04:54 PM
