Mojave
Old May 17, 2000 | 09:43 PM
KSFMojave250's Avatar
I own a mojave and I wanted to know if it was possible to make the mojave as fast as the 400 EX but without putting a big bore kit.
List the mods if possible.
Thanks.
Old May 17, 2000 | 10:14 PM
Guest
Guest
Posts: n/a
No. Serious motor work including a huge cc bump would be needed.
Old May 18, 2000 | 05:31 PM
suzukiboom's Avatar
maybe try getting a good aftermarket pipe(super trapp ids2,cobra jet,white bros) re-jetting your carb, sproket 13-tooth,18 inch tires(if you want to beat him of the start)getting an after market black box so your engine will rev higher.Lighter handle bars(aluminum) it will shed 2 pounds,that might help with speed.Higher octane gas might help to.(the stock top speed of a 400ex is only 64mph)
Old May 18, 2000 | 11:01 PM
JD250R's Avatar
I have White bros cams, Cobra JET pipe, 36mm carb, 13,41 sprokets, 20inch rear tires, ported, polished, wiseco ceramic coated piston, KLR250 black box, UNI pod filter, and a lot of other stuff. In a drag race with a piped 400ex I am 3-5 bike lengths behind.
Old May 19, 2000 | 12:23 AM
JumpKing's Avatar
JD250,
Can you tell me more about the black box you put on your Mojave. Also did the sprocket change make much difference.
Thanks for any info you can give me
Old May 19, 2000 | 11:00 AM
KawasakiKid's Avatar
The 13-tooth gear change was a dramatic difference in my bike. The power was much smoother, not all in the first couple 1000 of rpm's. Also it got rid of the sputter I had at full throttle.
To the other person who was asking about beating a 400ex. In my opinion you're asking a lot. The Honda has 150cc on ya. Regardless, you'll end up putting a great deal of cash into your Mojave, which is inevitable.
Old May 19, 2000 | 04:51 PM
JD250R's Avatar
The 13 tooth sproket gave it a lot better gear spacing and top-end. What do you want to know about the black box?
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
