Xplorer 400 front wheel leaning in?
Old Jul 17, 2003 | 09:57 AM
grayowl's Avatar
Default Xplorer 400 front wheel leaning in?
Need some expertise here guys. Recently bought a 2000 Xplorer 400 and notice the front tire appear to be slightly leaning in at the tops, meaning the distance between the tops of the two fronts is slightly less than the distance between the two bottoms. The steering handle bars have a bit of play in them which I'm assuming is probably ball joints to fix, but can anyone shead some light on whether this "leaning" issue is normal or a problem. If so, what is needed to correct. It seems to drive great and no problem climbing rocks etc. I appreciate the help.
Old Jul 17, 2003 | 08:27 PM
highwayman's Avatar
I watched on ATV TV that with macpherson strut front suspension this is common. My SP335 it is the same way. FYI double swing arm suspension don't do it.
Old Jul 19, 2003 | 08:06 PM
PeterinAZ's Avatar
What you have seen is called "positive camber", meaning that the front tires lean inward slightly to make them track straight. If the tires were leaning out, called negative camber, the ATV would wander and veer from side to side as if the driver had a few beers. Your car has the same situation and the tires have positive camber, or inward lean. The amount of camber is not adjustable in the MacPherson strut suspension of your Xplorer and unless there is damge to the upper strut mount or to the lower A arm, the "leaning" of the tires is fine. Dontworryboutit.
Old Jul 19, 2003 | 09:47 PM
grayowl's Avatar
Guys, I appreciate the information. Here's a bit more info on my problem. I took the wheel off and I have so little room at the top of the tire, with front end weight or possibly going over rock ridges, the tire sometimes rubs on the end of the tie rod. It looks like it just started because the rubber bushing on the tie rod is worn off and the end where it rubs is quite polished. It alsmost looks like the whole tire assembly has to move down about an inch to get it away from the end of the rod. Any other thoughts???
Old Jul 20, 2003 | 01:48 PM
hotdog's Avatar
do you have stock tires size or have you put on larger tires that could cause the problem
Old Jul 20, 2003 | 11:59 PM
grayowl's Avatar
Hotdog, maybe you are right. I bought the quad with the tires on but a commercial fisherman owned it and probably the tires he would use would need to be good in snow. What is the stock size tire for the 2000 xplorer 400.
The tires on it now are Mud Runners A125 - 8 -12. Any other thoughts?
Old Jul 21, 2003 | 12:19 AM
hotdog's Avatar
Sorry i don't know what the stock tire size would be ..I have a 2002 SP 500..But if you posted that topic i am sure somebody would...
Old Jul 21, 2003 | 12:31 AM
grayowl's Avatar
found it in the polaris page. I made a mistake in my tire size but the web site shows 25-8-12's which is what I have. No further ahead then, but still looking.
Old Jul 21, 2003 | 02:55 PM
PeterinAZ's Avatar
Are there marks on the tire where it has been rubbing? Is the mark all the way around the tire, or just on one area? Does the tie rod on the other side have the same wear mark?
ghost civic
Jul 20, 2015 12:36 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
