Help 500 h.o. prpblem
Old Jul 17, 2003 | 02:25 PM
Agustis's Avatar
Default Help 500 h.o. prpblem
My 500 just decited to start running bad.It starts ok,runs fine,idols ok,open it up and it boughs down bad.Changed plug seemed to help got it up to 53 giving it gas slow.Then back to the same problem.Open it up it putts bad.Help????I could only get it up to about 25m.p.h. when the problem started.This happened all at once.I live out in the country and dont know a lot about this machine its a 2001 model.I found this site and it seemed cool any help will be cool. Agustis[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Jul 17, 2003 | 05:18 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Check the throttle cable adjustment by the handlebars.
Old Jul 17, 2003 | 11:25 PM
yoopermike's Avatar
i'm no mechanic but check this out... see if the vent tube under the seat got pinched, it should be by the snorkle.
Old Jul 18, 2003 | 10:06 AM
Agustis's Avatar
The cable seems ok.Any change does change the way it runs .The vent tube also seems ok.Any good way to set the cable,or is trial and error the best?It is touchy.I worked on it last night and didnt get anywhere.I will try again today,that cable is sensitive.Thanks for the help,any other comments would be cool,since i still have a problem.Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 18, 2003 | 12:44 PM
Yeller500HO's Avatar
Adjuct the cable until you have 1/16th inch of play in the thumb throttle. Also do a seach on all the atv boards, you should find a lot of helpful info.
Old Jul 18, 2003 | 02:01 PM
Agustis's Avatar
ITS FIXED,THANKS GUYS FOR ALL THE HELP.YOU ROCK
Old Jul 18, 2003 | 02:03 PM
Tell us what the problem was, if you don't mind.
thanx
Old Jul 18, 2003 | 05:20 PM
kaw4life's Avatar
I am hoping someone can help me. I have a '97 Polaris 500 XPlorer. I can hear the drive belt rubbing the plastic case. It has an bolts to adjust the cover, but nothing seems to entirely fix the problem. Any ideas???
Also, the rear brakes squeel terribly when they get wet. Pads are good. When I lubricate the spline that the rotor floats on, it helps. I can't seem to narrow it down. Any help would be appreciated...Rob
Old Jul 18, 2003 | 10:28 PM
NCScrambler's Avatar
The older clutch covers were very thin and very close to the clutches. Heat over time will shrink the cover and also inadvertadently pushing up against the cover when riding will cause it to rub. You have two choices, put up with it as long as you can until it rubs a hole through or replace it with a 2001 or newer cover. 2001 and up on the 500's got an updated cover which is thicker and slightly further away from the clutches, the outlet size was also increased to allow better cooling. In 2003 the cover's got a drain plug added. My cover has been rubbing for about 2 years now and finally the last time I went riding it wore a hole through. Sorry, can't help with the brakes.
Old Jul 19, 2003 | 01:49 PM
cop's Avatar
cop
Try trading your polaris 500s in and buying a Suzuki Vinson 500, that would solve all of your problems.
