Possible choke problem?
Old Jul 17, 2003 | 06:20 PM
allan264's Avatar
Default Possible choke problem?
I have a DRR-90 which starts and runs fine for a short period of time, (2minutes) upon initial startup and then once the fuel from the carb is burned it continues to run fine at idle speed but once you try to give it gas it stalls. You can continue to run at idle speed just fine but thats it. I have changed filter, completely removed all fuel lines including carb and thoroughly cleaned....To no avail! Any ideas would be greatly appreciated!I thought maybe it could be choke related?
Old Jul 17, 2003 | 07:02 PM
RacinJason's Avatar
It could be choke related, however I'd start with float levels and carb settings
Have you made any adjustments to the carb needle?
Is this a two or four stroke?
Old Jul 18, 2003 | 12:38 AM
kidsatvracing's Avatar
Do you still have the stock air box on?
Maybe it is trash above the needle and seat or trash floating around in the fuel bowl.
Old Jul 18, 2003 | 07:23 AM
TRexTommy51's Avatar
You have a fuel problem somewhere. You are getting enough flow to run it at idle biut not enough for anything above that.
Old Jul 18, 2003 | 11:22 PM
LT80's Avatar
LT80 Expert
I've seen petcock problems before. Maybe dirt in the petcock or something.
Just a thought
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
ghost civic
Jul 20, 2015 12:36 PM
timster911
Jul 13, 2015 01:57 PM
Shifts
14
Jul 13, 2015 08:41 AM
