new tires&wheels for my scrambler
Old Jul 19, 2003 | 11:44 PM
scrambler420's Avatar
Default new tires&wheels for my scrambler
i need to buy new tires and wheels and dont know what i wanna get.im looking at puresports realtor rears and bandit fronts,how are the realtors for trail riding?i wanna go with 20x12rears and 21,7fronts,should i stick with a 10 inch wheel in the rear or go with a nine?and what width should i get?i really dont wanna go with a different offset i dont think unless i should?what is the stock wheel offset?please give me your thought guys thanks
Old Jul 20, 2003 | 12:24 AM
JWtrailblazer250's Avatar
I think you should get some ITP T-9 aluminnum rims with the itp mudlites.My friend has them on his 400 scrammy and it looks pretty sweet,I think I am going to get some t-9 rims and put mudlites on the back and then some holeshots on the front for my TB.
Old Jul 20, 2003 | 07:57 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
The mudlite/itp rim combo is what we are getting. We may even spring for the beadlocks.
Old Jul 20, 2003 | 09:31 PM
the smallest mudlite i can get is a 22,and like i said i wanna drop down to a 20 in the rear
Old Jul 21, 2003 | 09:41 AM
USMCQuader's Avatar
Why do you want to drop the rear tire size? More torque? Just change the sproket. You will want ot keep the tire size for suspesion and steering geometry and so forth. I have a 02 500 Scrambler and just took mine out with the douglas .190 and mudlites (stock sizes) and they are AWESOME. Worth every penny!
Old Jul 21, 2003 | 01:11 PM
i wanna drop tire size for more tourqe but more importantly i want the machine to be lower so it will handle better,im sick of doing donuts and being pretty much thrown off the machine.
smaller tires will give it less body roll..
Old Jul 21, 2003 | 01:17 PM
USMCQuader's Avatar
Smaller tires is ONE way of giving it less body roll. Another is better suspension (or tighter), more power to break the tires loose harder (and thus less tire grabbing enforced 'roll') and yet another is better tires, which the mudlites are much stiffer.
Let us know what you decide and how it works for you.
Old Jul 21, 2003 | 01:20 PM
Predator03's Avatar
If you are still running the stock tires on your machine, and upgrade to a 6 ply, it will help with the body roll. Also, you may want to check the rear shock and see if it is still at the softest setting. A lot of times, the factory setting is softest. When I had my Scrambler, I put Holeshot xct's, mounted on Douglas 190 rims. An excellent combo. Although, you may want to look into the ATR's. Also, a gearing change to a lower gear, will help in snapping that machine around.
Has anyone here tried a gearing change on the Scrambler? Does it affect your four wheel drive? Or is that only a concern if you make the front and rear tires the same?
Old Jul 23, 2003 | 09:52 PM
im not sure what i wanna do yet..how will my scrambler ride with 6 ply tire?will it be rougher?anyone have a clue on how much top end i will loose with the smaller tires?
fordfaithful21
Dec 7, 2015 05:52 PM
oliveiracarlos
19
Nov 11, 2015 05:49 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
