400ex problem help!!!!!
Old Jul 22, 2003 | 03:59 PM
shutterman400ex's Avatar
Default 400ex problem help!!!!!
my 400ex started using oil real bad and i cant find no leaks or nothing i change oil every month and watch it real good do you have any ideas?
Old Jul 22, 2003 | 04:05 PM
RapYosi's Avatar
your rings are bad, it's time to rebuild your engine
Old Jul 22, 2003 | 04:54 PM
how much do you think that will cost?
Old Jul 22, 2003 | 08:11 PM
jimford's Avatar
It all depends on your mechanical skills. If you pull the head off and bring it to the shop, it will save you some cash. You can reassemble it your self if you have the book and the time.
Old Jul 22, 2003 | 11:16 PM
do i have to bore it out?
Old Jul 22, 2003 | 11:44 PM
HondaMan400EX's Avatar
You may just need to buy new gaskets and replace them..
Old Jul 22, 2003 | 11:45 PM
and o-rings and seals..
Old Jul 26, 2003 | 10:23 AM
jimford's Avatar
If you follow the manual and take the head off, take it to a shop and have them check for wear. If it does need to be bored you have a chance to put in a higher compression piston while you have it apart. Get a little more HP. Putting it back together is pretty easy. The only thing that I hate doing is adjusting the valves. But that just me.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
