My God I forgot to look.. Help...
Old Jul 22, 2003 | 04:09 PM
MudStud's Avatar
Default My God I forgot to look.. Help...
I got the new seals for water pump but I forgot what direction they go.. Do the springs face each other? the they face the same direction to or away from the motor? or do they oppose each other??
I feel goofy.. I looked at the manual and the pic sucks, it looks like the springs oppose each other..
Old Jul 22, 2003 | 04:46 PM
JSsDS's Avatar
The springs should face the coolant. I have not looked at the assy but they seal the coolant pressure from the engine oil and atmosphere and the springs always face the pressure.
I hope that makes sense.
If you have seals on either side of the impeller, the spring side should face the impeller.
hope that helps
Old Jul 22, 2003 | 09:27 PM
KenDS's Avatar
The seals face AWAY from each other. Spring on inner seal faces crankcase to stop oil from entering coolant. The outer seal has the spring facing you to keep coolant out of the oil.
It is also a good idea to put a small nail thru the weep hole after seating the inner seal to keep you from driving the outer seal in to far and closing off the weep hole, afterwards just pull the nail out. If you cover the weep hole, when the seal fails next time the coolant will have nowhere to go but into the crankcase.
Old Jul 22, 2003 | 09:40 PM
JSsDS's Avatar
Thanks for clairifying Ken. Hope I didn't screw you up with my (vague) reply Grady.
Old Jul 22, 2003 | 11:58 PM
MudStud's Avatar
Ken & JSSDS, thanks.....
Ken, I read your info on using a drill bit.. I searched the posts!!! but I only found your informative review on the drill bit.. I want to tap it but I will wait until this winter to pull it off, i just want to ride!!!!
JSSDS - How did that carb turn out for you??
Old Jul 23, 2003 | 01:57 AM
JSsDS's Avatar
Tell ya the truth, I havn't put it on yet. The DS takes a backseat to the sea-doos in the summer time. Just too damn HOT to ride anywhere around here in the summer so the water is my refuge.
We may be going to Pismo soon so I'll put it on then.
Matt123
Sep 29, 2015 01:29 AM
Newzboy
May 22, 2001 03:22 PM
CoolAssToys
Feb 24, 2001 12:37 AM
mudmachine
Dec 15, 1999 11:33 AM
Stumpy2
Nov 30, 1999 08:22 PM
