SP700 stuck in 4WD
Old Jul 22, 2003 | 04:37 PM
RINCON's Avatar
Default SP700 stuck in 4WD
A guy that i ride with has a sp700 that is stuck in 4Wd, he doesn't like it because it's a lot harder to steer, and doesn't handle as good. It's an '02. Any ideas?
Old Jul 22, 2003 | 05:15 PM
lovemud's Avatar
Has he tried unpluging the front hub, and looking for 12v? It sounds like there's a short in his handlebar switch.
Old Jul 22, 2003 | 06:01 PM
RookWV's Avatar
Has he put it in Reverse and tried that? I know if one hub gets stuck you can put it in reverse and back up a little bit and then it should release....
Old Jul 22, 2003 | 09:19 PM
NUTZ's Avatar
I AGREE WITH LOVEMUD, 1ST YOU NEED TO FIND OUT IF ELECTRICAL OR MECHANICAL, THIS UNIT HAS A CENTRALIZED HILLARD SYSTEM THAT ENGAGES AT THE CENTER INSTEAD OF AT EACH WHEEL. HAS HE RECENTLY CHANGED THE OIL IN THE FRONT T-BOX?
Old Jul 22, 2003 | 10:22 PM
MnFriesen's Avatar
im not to knowledgable on the 700 but my dads 500 magnum's 4 wheel drive would not kcik out because the last time he did an oil change the dealer gave him the wrong grease for the zerks. it was to hard of a grease and that is what caused it. later
friesen
Old Jul 22, 2003 | 11:15 PM
RINCON's Avatar
It only has 700 miles on it. i'll try that on Saturday with him.
Thanks
Old Dec 7, 2004 | 04:05 PM
Chawness's Avatar
Sorry to bring back an old thread, but did you get this resolved? My 700 is doing the same thing.
Old Dec 7, 2004 | 07:21 PM
jwyles's Avatar
Anyone consider putting select topics into like a sticky troubleshooting section?
Jeff Roper
Feb 1, 2022 11:48 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
