What will race quality gas do for the V-Force?
Old Jul 24, 2003 | 12:14 AM
brewster2003's Avatar
Default What will race quality gas do for the V-Force?
Is there any performance gain going from 93 octane pump gas to the race quality 105-112(?) stuff?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 24, 2003 | 12:38 AM
TheFatGuy's Avatar
try the ultimate four race gas gives a 6% increase.
Old Jul 24, 2003 | 12:42 AM
6% increase in HP? Seriously?
Old Jul 24, 2003 | 12:46 AM
orangerocket926's Avatar
I can tell the diffence in 93 octane and race gas....i run nothing but race gas in mine, it will prob. burn the piston up but i hope it does it within the first 6 months.
Old Jul 24, 2003 | 12:31 PM
green700's Avatar
The compression ratio of the V is 9.9:1. Compression the YFZ 450 is 12:1 and it uses pump gas. What I'm trying to say is that race gas will do nothing for you unless you have a high compression engine. Race gas does not produce more power, it is simply harder to burn. It prevents premature ignition in high compression engines (like 13.5:1). It will not hurt your engine, but there is absolutely no reason to use it unless you increase the compression ratio of your engine. Of course it's your money so feel free to buy all the race gas you want.
Old Jul 24, 2003 | 01:17 PM
XC800's Avatar
I agree with Green700 100%. We get into this every winter with the sleds. You need a higher compression engine to make up for the higher elevations with thinner air. That is when the hi octane come into effect. Some of the guys run a "dial a dome" which allows you to change the heads on your unit to add or take away "squwish" or compression. Running a 10:1 with high octane is a waste of money.
Old Jul 24, 2003 | 01:39 PM
Puttnutt24's Avatar
I too learned this building Harley engines. Save the bucks for other things,we all know there out there. Later all,Putt
Old Jul 24, 2003 | 02:43 PM
This is all good info that can save all of us some money. What octane ideally should then be run in the V? I have not checked the manuel yet to see what they recommend, but I will.
Johnny Mac
60
Dec 14, 2019 06:13 PM
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
