200X clutch Help ASAP!!!
Old Jul 25, 2003 | 09:26 PM
Biggs74's Avatar
Default 200X clutch Help ASAP!!!
I am in the middle of replacing my clutch in my 200X and I cant remove the the 3 screws on the oil filter rotor they wont budge so please someone tell me how I am suppose to remove them with out stripping them out.
Thanks,
Jason
Old Jul 26, 2003 | 02:55 AM
nudescreamngmike's Avatar
If you haven't got them out yet you'll need a tool called an impact driver .It's a type of screwdriver that you hit on the end with a hammer and it drives the screw out . I had to do the same thing with mine . Craftsman has one for about $17.00 and snap on has one for about four times as much. I would have stripped mine if I didn't use it. After you get the cover off you'll need a special socket to remove the nut. I made one with an old socket and a die grinder. Good luck.
Old Jul 26, 2003 | 10:06 AM
Biggs74's Avatar
Thanks I did get the screws out and everything together then I was putting on the side cover and the clutch arm on the cover didnt have much sping to it and noticed the spring was shot and also it wont click into any gears just hangs there now like its not catching so now what do i need to do????????????????????????
Jason
Old Jul 26, 2003 | 03:41 PM
dragracer789's Avatar
adjust the clutch lever so that it has a little bit of slack before the clutch starts to ingage.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
slowgsxr97
Sep 8, 2015 07:33 PM
