Drag info please
Old Jul 26, 2003 | 02:46 PM
racerx5x5's Avatar
Default Drag info please
Going to drag my quad next weakend and could use a little info. I have done some draging on sand but never on dirt. I am running 15-42 gearing (for sand) Should I go back to the 40? Also sould I start in 1st or 2nd?
Old Jul 26, 2003 | 03:00 PM
Birdoprey's Avatar
I'm no pro on dirt and have never been on sand, but i can offer a little....
What size/type of tires are you gonna run? The paddles will hurt your mph on dirt.
Are you gonna run 300ft or 600ft?
Are you running an aftermarket cdi?
With your gearing and a 20" tire, you'll hit the limiter just before the 600ft mark unless you have a higher than stk limit.
With your gearing, i would take off in 2nd. Some say they let the clutch go in first and immediatly shift to second and do well. I did better leaving in 2nd.
Hope some of this helps.
Now if we are talk'n two wheels and on pavement, i can really help...
Old Jul 26, 2003 | 03:04 PM
racerx5x5's Avatar
22" Holeshots. Man do thay hook up[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 26, 2003 | 03:46 PM
DCryder's Avatar
With the 22" tires 15/42 should be perfect!!
Are you running with a wheelie bar? If not, do yourself a favor and go get two pieces of 1" black iron water pipe, cut 18" long and drill holes 17" center to center to replace front shocks so you can dump the clutch and get a much better holeshot.
I run 22" 4-Snows with 15/40 gearing and ALWAYS take off in 2nd.
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
