Oil light flashing on?
Old Jul 27, 2003 | 12:04 AM
NewToThis's Avatar
Default Oil light flashing on?
The oil light flashes on both tb's and my 400 scrambler.....i noticed this today....when going donw a hill or when i would hit the front brakes....i have noticed it on all 3.....like i said.....these are new to us.....i have the tb's service when we got them 2 weeks ago....not service mine yet....is it normal for the oil light to flash on like that.....how do i check the oil level?
Old Jul 27, 2003 | 12:24 AM
JWtrailblazer250's Avatar
When the oil light comes on that means it needs oil,the oil cap is located on the front of the plastic.You dont really want that light to come on so you need to check regulary.
Old Jul 27, 2003 | 12:26 AM
NCScrambler's Avatar
No that is not normal unless your oil is low. To check, you need to unscrew the oil reservoir cap at the front of the machine, you should be able to see oil in the reservoir and it is best to keep the oil tank full at all times. The full level is at the bottom of the threads for the cap.
Old Jul 27, 2003 | 12:44 AM
Do you grease them and do you lubicate the chain's if not you need to do that about after 3-4 rides.
Old Jul 27, 2003 | 12:59 AM
TrailBlazerguy250's Avatar
dont fill the oil to high i did that and i had oil runing up through the oil vent tube. dont want that to happen either
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
panicmanic
Sep 28, 2015 12:59 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
