oil cooler for warrior
Old May 22, 2000 | 10:00 AM
97warrior's Avatar
Does anyone have a oil cooler on there warrior ,and if so how and where did you mount it .I'm considering doing this mod before summer hits us with 90degree weather.I'm also thinking about getting my pipe ceramic coated.
Old May 22, 2000 | 10:22 AM
THEXOTIC1's Avatar
You should check around for shop that make the oil filter plate with the hose barbs coming out. I used an old street bike oil cooler and bought a plate from James Lucky it was $40. It works great and i saved alot of money than buying the complete kit.
Old May 22, 2000 | 10:55 AM
97warrior's Avatar
Thanks I'll check there ad for the plate .But how does the oil go though the cooler ,What i mean is ,is the stock oil pump strong enough to bring it through? And will the extra oil in the cooler flow back and over fill the case? Oh and can I mount a fan on it .
Old May 22, 2000 | 12:35 PM
THEXOTIC1's Avatar
I have this mod done on 2 bikes an 87 250x and a 96 TC405ex Tom Carlson has these installed on all the motors he builds. I have had no problems with the oil pump. It is strong enough to push up to the oil cooler its only 6-8 inches away. I Alos have a 99 Mojave they have fans on the raditor but my fan stopped working. I wouldnt reccommend a fan they will eventually corrode and stop working
Old May 22, 2000 | 12:54 PM
1BadWarrior's Avatar
Try looking in the back of the July issue of DirtWheels and look for the advertisment in the classified section for DirtMods. They make an oil cooler that requires no drilling or tapping. If I am not mistaken I think the kit will run you about $320. Kind of expensive but not a bad investment I was thinking of purchasing one but around here it doesn't get up in the 90's for long.
Old May 22, 2000 | 06:52 PM
Heapster's Avatar
Check it out.
http://homepages.ihug.co.nz/~crainic/Powroll_grunt.htm
(after viewing click on the "home" button at the bottom of the page and scroll down to "keeping it cool" for more info)
Here's how I mounted my oil cooler and stainless steel braided lines. Works great with my built 400cc motor.
The cooler from a street cycle is mounted vertically between the frame members right above my steering dampner. The oil pump cover is from a big-bear.
Good luck on your project.
Old May 22, 2000 | 08:41 PM
YFMRACER's Avatar
i have an oil cooler from a 400ex(I know its a honda part but it work and it wasn't that expensive)mounted between my front frame rails. I had to buy the short oil lines on the ex also to connet to it because honda has a wierd way of doing things. then i used the oil filter pieces off a kodiak and had lines made for it. a friend used the dirt mods kit and it uses the same filter pieces but cheap hoses and cooler. After a full season of hard woods racing it has held up great. what ever way u do it, it is something that is worth the trouble
Old May 22, 2000 | 09:11 PM
97warrior's Avatar
Thanks for all your replies ,And heapster nice site ,it was alot of help ,especaily the parts #list .I have a friend that owns a motercycle shop and he has alot of Japanese parts bikes lying around,so I'm going to look for a good one that will fit and has the hose niples still on it .I'll also take a ride up to the local heavy equipment hydrolic hose specailist.Also I'm going to look into getting my pipe ceramic coated,Will the ceramic coating chip off dureing hard riding?
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
