Mojave Kick start gear
Old Jul 29, 2003 | 08:29 PM
mojavekid13's Avatar
Default Mojave Kick start gear
Has anyone else had any problems with theirs and if so was it alot of $$$ to fix and how hard was it! THANKS SEANN
Old Jul 29, 2003 | 08:47 PM
Come on mojave guys!
I need your help on this one!
Old Jul 30, 2003 | 12:41 AM
TheFatGuy's Avatar
is it the idlear gear? know klx300 prior 03 had bad problems with the set up of the acr which in turn stripped the idler.
Old Jul 30, 2003 | 12:42 AM
mahnster's Avatar
i havent had any problems with mine.
Old Jul 30, 2003 | 09:45 AM
dork's Avatar
did they jam? i think the older ones 87,88 had problems with this.
Old Jul 30, 2003 | 10:39 AM
Well I know some one on hear must have replaced theres at some point!
Old Aug 2, 2003 | 04:23 PM
haywoodjalikme's Avatar
i've replaced mine a couple times, broken teeth.......1 is about $30 and the other is about $70
they're are a pain to change unlike my 200x where you just have to pop off a little cover.
Old Aug 3, 2003 | 06:06 PM
Cool cool
Did it make a rattling noise when you started it up when they were broke!?
Old Aug 3, 2003 | 08:03 PM
the times it happened to me the kickstarter lever either stayed in the down position or it just slipped and didn't grab anything.....i don't remember any clicking but it was a long time ago.
the problem could be farther inside where there is another gear.
Old Aug 4, 2003 | 01:18 AM
boob's Avatar
mine got so screwwed up and when i took it apart i found out that somehow it had worked the circlip off and it started to wobble then it jammed itself metal shavings everywhere but it was 70 bucks and the site i got it from has a 100 $ min order BTW it was the idler gear
