stoppie
Old Jul 29, 2003 | 11:48 PM
ridinsmooth's Avatar
Default stoppie
ok i can do wheelies and other stuff but cant do a stoppie can you give advice on how do you do a stoppie i know that was stupid[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 30, 2003 | 12:19 AM
DaSandBomb's Avatar
Default stoppie
Whats a "stopiee"?
Old Jul 30, 2003 | 12:41 AM
Default stoppie
you know when your doing wheelie front wheeles are in the air well a stoppie is when you stop your come up into the air i will try to find a pic for you
polarisisthebest's Avatar
Default stoppie
Ya i need some advice on doing stoppies too, it seems like when i lock up the front brakes it either slides or just stops the four wheeler. A stoppie is when you hit your front brakes and lean forward to balance on the front wheels.
Old Jul 30, 2003 | 12:50 AM
Default stoppie
man now knows how to do a stoppie
Old Jul 30, 2003 | 01:04 AM
yellowexracer's Avatar
Default stoppie
I can do them on pavement, I get going usually slow in 2nd, throw my 280lbs forward and brake hard.
Old Jul 30, 2003 | 01:22 AM
lilnotts's Avatar
Default stoppie
o really? how come i've never seen ya do it? [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 30, 2003 | 01:26 AM
ttyR2's Avatar
Default stoppie
Stoppies are much more common (and not terribly safe) on street/race bikes like a Gixxer. Used to do them all the time back when I raced.
Old Jul 30, 2003 | 02:18 AM
hondaracer305's Avatar
Default stoppie
i can throw my weight up to the front of the 300ex and hit the front brakes and do it, but on the banshee i have to sit on the handlebars and nail the brakes.
Old Jul 30, 2003 | 10:21 AM
JoshCVBz's Avatar
Default stoppie
Here's how it's done.....To start out, first gear is fine. Accelerate to the top so first, then pull in your clutch and put on your brakes nice and smooth, but firm. The next part is a little hard to explain because it has a lot to do with feeling, but as you are coming to a stop do a "double pump" with the brakes. The first pump will transfer all the weight forward, and then on the second pump throw your weight forward (you can squeeze your legs against the seat for more leverage). You probably won't get it right away, but you will with a little bit of practice. Some surfaces make stoppies really hard like grass or loose dirt. In fact, I have a very hard time doing a stoppie on the lawn. They are easy to do on pavement or hard pack....also in a field isn't bad either.
There a few video clips on our site www.cvboyz.com that you can download and maybe get a better idea of technique. The first vid listed on the page is something that we put together quite a while ago, and there are two labeled "Spring Fever" clips. Those were done like last month from a little bit of footage that I had.
Take it easy man.
-Josh
