Heavy duty Rappy parts?
Old Aug 2, 2003 | 12:43 AM
RoostItUp's Avatar
Default Heavy duty parts?
Well, my Rappy is finally almost done being fixed but I need to make sure it's gonna be as reliable as I can get it. I put the new Carrillo rod in and a heavy duty clutch kit but what else should be considered to keep reliability up? I was thinking a new one way because my starter already has problems with the high compression, is that a good idea? Any suggestions would be very helpful! Thanks!
Old Aug 2, 2003 | 02:53 PM
WallStreet's Avatar
Default Heavy duty Rappy parts?
Maybe Hinson basket, Sidewinder Sprockets, L&A Designs one way is a good idea, that's all I can think of right now.
Old Aug 2, 2003 | 03:39 PM
RoostItUp's Avatar
Hmm...one response, comon guys help a brotha out! [img]i/expressions/face-icon-small-smile.gif[/img] Anyother ideas? I gotta get everything ordered soon so I need ideas fast. And I'm thinking more along the line of internal heavy duty parts. Thanks WallStreet.
Old Aug 2, 2003 | 04:29 PM
WallStreet's Avatar
Since no one is helpin you out, Im gonna post again! Craycraft just came out with the head stud kit for around $230. It is supposed to be bullet proof on hi comp engines. If you havent already got this I would check it out. Doubles the torque levels on all the bolts. You are already getting the Carrillo rod, so off the top of my head I don't know what else to suggest!
Street
Also, how do you like your gears for draggin down at LS? I have heard alot of people tell me to get 14 front and alot of people tellin me to get 12 front. Thanks
Old Aug 2, 2003 | 04:44 PM
RoostItUp's Avatar
You deffinatly want the 14 tooth. I had low gearing (12 tooth) right when I got the engine together and after I bumped it up it made all the difference in the world with speed and acceleration! If you have the HP to push high gears then deffinatly use them! My gearing right now is about as high as I want it, I can almost get 2nd gear starts so when I get it back I'm gonna add a couple teeth to the rear sprocket to see how that helps. About that studded gasket kit, I'm gonna use the Cosmetic ones I have now and when I rebuild it later I'm gonna try to get those (if I can). Thanks again.
Old Aug 2, 2003 | 05:16 PM
RoostItUp's Avatar
I gotta question about that one way. Theres 2 things you can order, the kit and just the one way. The kit has the gaskets and the gear added on, is that just for if you already ruined your original one way? My one way is still in good condition so can I just order the one way and not the kit or do I need that gear and gaskets? Thanks.
Old Aug 2, 2003 | 07:02 PM
WallStreet's Avatar
If your one way is still good, your gear is probably still good, too. I would order a new gasket, though, because it tears coming off.
Old Aug 2, 2003 | 07:36 PM
RaptorRcR's Avatar
BigBubba...look at the gear. The sprags inside the one way actually groove the surface on the gear. If it is rough or shows any signs of wear, replace it. Most people just buy the one way and dont know why it goes bad in a month..and it's simply because of the gear surface. If I were you, I would buy the kit.
Old Aug 3, 2003 | 01:00 PM
warrior007's Avatar
If it hasnt gone out yet, or had any trouble you may be alright, but definitely inspect it like RCR says. When you need it, give me a call and I can hook you up 610-466-0448
Mike
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
coolguy420
Jul 10, 2015 01:17 AM
