Pred Problem Please Help
Old Aug 2, 2003 | 05:27 PM
Preddy's Avatar
Default Pred Problem Please Help
Ok heres what happened I went through some water and took it in the intake. So i pulled the plug (Is there only one or am i tripping) cranked it then after awhile got it started.. Didnt run so good for awhile but then it started to work good.. Then the Problems started Turned off the engine, for a short break after that It wouldnt start. The starter made a noice but thats all.. So then i got it pull started. Took it home and put it in the Garage. And tried to start it when i pressed the start button everything turned off. that happened twice then i messed with the Key and it started. I think the ignition switch is shot but Has anyone else had any problems like this.
Might Be
Water messing with the sensors
Ignition Switch
Maybe Battery Problem
I have no idea Please help.
Old Aug 3, 2003 | 08:42 PM
ProXPredator's Avatar
I just had my key switch replaced on my Predator. When I would turn it all the way on, kind of harshly, it wouldn't turn on the power. If I turned it slightly towards the off postition, it would turn on. Take it to the dealer, it's a warrenty issue. They should replace it for nothing. Be sure to have both keys, they send a new switch and keys for it.
Old Aug 3, 2003 | 08:50 PM
Preddy's Avatar
Well thanks, but i found the problem it wasnt the Key. Which it seemed to be it was The battery cable wasnt tight enough.. Kinda weird cus the power would come on but the starter wouldnt turn over. Now i tightened it now everything is working.
Old Aug 3, 2003 | 09:09 PM
Cool, good process of elimination!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
