Stock Polaris spring in V Force review!
Old Aug 3, 2003 | 04:19 PM
GE4x4's Avatar
Default Stock Polaris spring in V Force review!
I decided to put my brothers stock Polaris spring in my 700 to see how it would do. The first thing I saw was, the Polaris spring was 1/2" longer then the 700, (Polaris was 2 7/8, 700 2 3/8)and a wider coil. So to get the Polaris spring down to the lenth of the 700's, it took 20lbs of force. I don't know when the 700 engages, but I think it's around when the spring gets to 2". So it took 20lbs of force to get the 700 spring to 2". To get the Polaris spring to 2" it takes 46lbs, or 26lbs more when it's at the same lenth as the 700's. So if this is true, The Polaris spring should engage a little higher then the 700 stock set up. Now the install.
After installing, the Polaris spring engages about 200-300rpm higher then the stock set up, yet still very trail friendly. I took it on a 20 mile trail trip threw rocks, hills, mud, and some fast area's, and came back happy with this set up. The flat spot that I always feel about 40mph was gone to. It just climbed all the way up. I was not able to get a full speed run on it, but on the low end it felt quicker and snappier. I don't know what the full up-shift of the 700 is, but it takes 117lbs of force to get the Polaris spring to 1 1/4" and I don't feel the 700 stock spring is that high. So over all, I like it, and it didn't cost me anything. So if anyone knows someone with a stock Polaris spring, you might want to give it a try.
Old Aug 3, 2003 | 04:28 PM
scrambler420's Avatar
where do you ride in nh ge?i live like 30 minutes from you
Old Aug 3, 2003 | 04:35 PM
STAKK's Avatar
What was the Polaris spring for???? Scrambler, Sportsman 500, 600, 700, Trailblazer what???
Old Aug 3, 2003 | 04:41 PM
GE4x4's Avatar
420
I ride in Hillsboro, and Weare.
Stakk
It came out of a 02 Scrambler 400 4x4. But I thought all Polaris had the same stock springs.
Old Aug 3, 2003 | 04:56 PM
no not all stock polaris springs are the same..
Old Aug 3, 2003 | 11:29 PM
engine9680's Avatar
ge4x4 what color was that spring red i hope or white i have both from my old trailblazer 250
Old Aug 3, 2003 | 11:44 PM
KevinM's Avatar
This is what I've been telling you guys all along. A spring in the 3" vicinity will do wonders for the wall that the stock V's seem to hit. The 2 springs I've been using are both 2 7/8 inches long, one with thicker coils than the other. I just bought a new spring that's a little over 3 1/4 inches long with thin coils rated at 60/200 that I'm going to try out soon.
Old Aug 4, 2003 | 08:42 PM
GE4x4's Avatar
It just look like a non painted spring. Did not see anything on it to see a color.
clsharky
Jul 13, 2015 02:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
