Concerned info about oil.........
Old Aug 4, 2003 | 02:12 AM
MOPARD's Avatar
Default Concerned info about oil.........
I was told that it is safe to mix Yamalube 2-S in the tank of my 2000 Blaster at 32:1. I am concerned about this because they make a special oil for use when the oil pump is bypassed. What is your info about this?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 4, 2003 | 02:19 PM
shlekter's Avatar
what do u mean mix.....if u fill the oil tank up u should b good to go......unless u want a richer mixture u can put some oil in the gas but the oil injector and 32;1 may b a little 2 rich
Old Aug 25, 2003 | 12:39 AM
MOPARD's Avatar
I mean bypass the oil pump and mix it with the gas by the gallon[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 25, 2003 | 12:43 AM
warrior007's Avatar
yeah that should be safe. If you bypassed it you have to mix it with something but follow the recommendations on the container, usually there are mixtures and ratios.
Get yourself a ratiorite cup to make it easy, available at most dealers.
Old Aug 25, 2003 | 03:31 AM
MOPARD's Avatar
Which would be best the Yamalube 2s or the 2r, I think it is the 2r
Old Aug 25, 2003 | 05:00 AM
duckdiaz's Avatar
Yamalube 2r is just fine
Old Aug 25, 2003 | 08:32 AM
99blueblaster's Avatar
You can premix either 2s or 2r id does not matter. 2r is the better or should I say more expensive. I ran 2s in mine I put 3 years over 160 hours on my topend and it looked like new when I rebuild it. Either one will do fine.
Old Aug 27, 2003 | 03:47 AM
MOPARD's Avatar
Thanks.[img]i/expressions/face-icon-small-cool.gif[/img]
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
