What Compression With NOS?
Old Aug 6, 2003 | 10:31 PM
WallStreet's Avatar
Default What Compression With NOS?
I am running a 20 shot NX on my stock motor. Down the road I would like to make the motor itself better. I am thinking a Hot Cams stage one or stage two (depending on peoples advice) Craycraft or Robertson's highest level of porting, and a forged (manufacturer???) stock compression or maybe 10:1 stock bore piston. Does anyone make a stock or close to stock comp. piston that is forged?? Also, the reason I am doing this is because I hear high compression engines do no work very well with nitrous. Thanks alot in advance.
Street
Old Aug 6, 2003 | 10:51 PM
RAPTORAZ's Avatar
High compression and Nitrous work fine together provided you keep it from detonating. My 1969 Mach I with 11:1 compression did fine running a 200 shot. The key is to run the best(read highest octane) fuel you can find.
Old Aug 6, 2003 | 10:57 PM
StockRappy's Avatar
are u running nos, like activated, as in u push a button or as in it uses a little when u go into gears? i dont know much about nos...
Old Aug 6, 2003 | 11:04 PM
AdamsBadDS650's Avatar
I will have run up to a 25 shot (same Nx kit as you) on my 13:1 686 motor. I know someone who has used a 25 shot on a stock motor for quite some time with no problems. I even looked at his piston when he tore it down, and it looked pretty good. As far as I know, there shouldn't be anything wrong with your stock piston for Nitrous. I think Dollarbillz has used up to a 50 shot on his 13:1 motor, too. So, there is nothing wrong with hi-comp and nitrous. I use 114 octane race gas, and a colder spark plug.
Old Aug 7, 2003 | 12:35 AM
14mins's Avatar
Wallstreet- a 10-1 would do you better for nos. You can run any piston with nos BUT most of the ones that i have seen have gotten the best results from using lower comp pistons. Craycraft stocks 10-1 727 pistons. That would be a killer combo. A lazy 727 till you hit it with 60hp shot of nos. Of course you better stud the top end. You have a hp gasket in your pator?? I would toss a stage 1 cam in there real soon. The gain would be worth the 125 dollars.
Old Aug 7, 2003 | 12:46 AM
ScoobyDFW's Avatar
why didn't Dollarbillz run the NOS at the ATPT Summer Nationals, he might of had enough to win the open class.
Old Aug 7, 2003 | 02:04 AM
14mins's Avatar
Scooby- Dollarbills did not have enough time to get the NOS dialed in before the race. [img]i/expressions/face-icon-small-sad.gif[/img]
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
