250 mojave top speed
Old Oct 1, 1999 | 11:21 PM
mojave4's Avatar
I have a 1995 kawasaki mojave.Does anybody know top speed?Is it between 55-60mph or is it less than that.
Old Oct 2, 1999 | 02:11 PM
RidE's Avatar
As far as I have heard, a completely stock mighty mojave will max out right around 55mph. Do you have mods?
- 1986 Honda TRX250R, 1996 Kawasaki Mojave, 1998 Kawasaki Mojave, http://www.geocities.com/MotorCity/B...8090/home.html
Old Oct 2, 1999 | 05:49 PM
mojo's Avatar
I dont know how acurate it is, but my friend has a quadrunner 500. His quad tops out at 56 mph on his speedo and I walk by him by at least 5 mph and I am slightly modified.
Old Oct 3, 1999 | 12:45 AM
mojave4's Avatar
Thanks for the replys.My mojave is completly stock except I put a cobra pipe and muffler on.How well does a K&N jet kit and filter work?Will I notice a difference in performance?
Old Oct 10, 1999 | 11:09 PM
RidE's Avatar
You will definately gain something, that should put you at about 60mph. It won't be mojorly noticeable, but you will be able to tell the zip.
Old Oct 15, 1999 | 09:48 PM
mojo's Avatar
When I got my mojave I bought the K&N filter and jet kit. When I took the carb apart I found that the previous owner had allready jetted it.The kit recomends the 030 main jet and I already had a 032. I used the 034 which is supposed to be used with an aftermarket pipe that I dont have yet and got noticable results. I was running a 14 tooth front and stock rear sprockets (I just changed the front to a 13) and was having trouble keeping the rear tires spinning up long steep hills in second gear. Changing the main jet and fuel needle gave me enough to keep them spinning.The 13 tooth front sprocket has made a difference too. Now the front end comes up easier and it will hold a doughnut till it runs out of gas.The jist of my babbling is that they are beneficial upgrades that will increase performance.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
