stripped screw help
Old Aug 17, 2003 | 11:35 PM
savage21's Avatar
Default stripped screw help
how to get a stripped screw out{ the screw to take the oil pump off} { 400 scrambler
Old Aug 17, 2003 | 11:41 PM
jsyi's Avatar
Drill the head of the screw and then tap it
Old Aug 17, 2003 | 11:43 PM
scrambler420's Avatar
try using a easy out
Old Aug 17, 2003 | 11:47 PM
Cowboy35's Avatar
If it is the screws to get the cover plate off I did the same thing when I took my oil injection off. Drill the heads off all the screws and then take the cover off. Then use a set of vise-grips to loosen the screws. They should come right out after this. PM me if you have anymore questions.
Old Aug 19, 2003 | 07:36 AM
USMCQuader's Avatar
I stripped the screws on the carb float assembly. Take a dremel or even a jig saw with a metel blade and cut a slot in the screw. Use a large philips. Done!
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
Jackg17
Sep 26, 2015 09:30 PM
