Scrambler 4x4 switch not working
Old May 30, 2000 | 10:58 AM
roder's Avatar
I own a '98 400 Scrambler 4x4. The 4x4 switch was working intermittently, but now it does not work at all. I checked the switch itself along with some wiring, but I'm at a loss as to what to do next. Does anyone have any ideas??
Thanks in advance
Old May 30, 2000 | 11:58 AM
Loyal's Avatar
I had a similar problem with my 96 Xplorer 400. I dismantled the button (no big deal) cleaned up the contacts and put it back together. That worked for a while until the problem came up again.
I was at a loss so I brought her to the dealer who replaced the switch in the gear selector. It looked similar to a toggle switch with a bunch of wires that attached to the circuit board.
I was alos told that it may also be a cracked wire that runs to the magnets in the front wheel.
Hope this helps.
Old May 30, 2000 | 04:08 PM
mudmachine's Avatar
Roder,
Put the shifter in Forward, turn the key on, at this point, the reverse light and neutral light should NOT be on...
Naw.. take a meter and check for voltage going INTO the AWD switch.... If you have power there, make sure you have power going OUT of the AWD switch...
I started having problems out of my 97 Scrambler 500 about a year ago.... I got fed up with it, and rewired part of it so that the OVERRIDE button is completely bypassed and the Reverse Rev-Limiter is bypassed.
Now, when you go to reverse, it has full power, and if the AWD switch it engaged, you have AWD...
The older style button you have is like the one on my 97, they are prone to corrosion and failure.. Disassemble it and clean it with contact cleaner and a SMALL fine file or emory cloth..
Good Luck..
Old Sep 18, 2019 | 06:24 PM
John pendleton's Avatar
Weekend warrior
Default Etc demand drive switch scrambler 400
my etc switch is not working either and I cannot get 4 wheel drive to work how do I fix it scrambler 400 98 help whould be great can l wire a new switch in stead of it thanks
bigpollyboy
Oct 29, 2015 05:32 PM
tt425
Dec 15, 2011 09:23 PM
carnalchris
Jan 29, 2010 07:26 AM
jchunn
Jan 14, 2009 10:57 PM
scramblin05
Mar 5, 2004 06:53 PM
