What switch on the trans is the 4x4 switch?
I have a 2001 Sportsman 400 4x4. It has 2 switches on the trans. Which 1 of the switches makes the 4x4 work. I had someone tell me about 1 yr ago that the switch was bad. I have been using 2wd. I need to get it repaired. I can't get a returned phone call from a Polaris mechanic friend of mine. I want it fixed this weekend. Thanks
I don't know for sure which switch runs what, but you should be able to use a test light or multimeter across the switches and see if they open and close as they should. The wiring was pretty simple on those machines, you can probably trace the wires from the solonoids on the front axle up to the connector board then to the switch on the bars and whatever else they run through. I had a 300 about the same year that the 4x4 didn't work when in reverse, I just wired it so I could put power to the switch anytime the key switch was on, that way it didn't care what gear it was in, the 4x4 would work.
