rotors all rusted, can i save them???????
Old Aug 28, 2003 | 12:59 AM
jiffy's Avatar
Default rotors all rusted, can i save them???????
i just got a quad off my buddy for free. it needs the engine rebuilt but thats another post. anyways the rotors are pretty rusted. can they be saved? i know after driving it for a while and braking some of the rust will come off but will are they savable? the quad has been sitting for about 3 years.
thanks
jeff
Old Aug 28, 2003 | 12:16 PM
95wolv's Avatar
If it is just the fuzzy surface rust, wire brush or sand it, if you have access to a sandblaster, take the rotors off and it will make them look great. If the rust has pitted into the surface at all, get rid of them, the pits will cause brake noise and uneven or rapid pad wear due to debris catching in the pits.
Old Aug 28, 2003 | 02:29 PM
nyroc's Avatar
Technically 95 wolv is right, but if it is just going to be a beater, try it first and see if it stops Ok.
Old Aug 28, 2003 | 04:06 PM
jiffy's Avatar
well basically it is a beater. The engine is out at my buddies house gettin rebuilt. I am in the process of repainted the whole frame. Im not trying to make it perfect just a couple coats of spray paint and a couple clear coats. nothin expensive.
The whole thing is apart, i'll just take the rotors off and wire brush and sane them clean. what grit sandpaper?
jeff
Old Aug 28, 2003 | 05:57 PM
95wolv's Avatar
Either 80 or 120 grit, you want to get down to the good metal, and remove any glazing from the old pads, a fresh metal surface will help your new pads seat better and wear longer.
badgerboy1
Sep 26, 2017 06:11 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
